Chevy bellhousing demensions - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2009, 07:08 AM
6426yy's Avatar
Chevy bellhousing dimensions
Does anyone have a photo with the measurements on it? I've been looking around on the net for a while and can't seem to find anything. I'm building an engine test stand and don' know how deep the 'housing is and the distance between tranny mount bolts (3-4 Speed). Thanks.
Old 04-19-2009, 11:58 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
Well, I can't help a whole lot on the bellhousing depth until I get home (a couple days away right now since I'm now a truck driver), but the other measurement is it for the crossmember mount bolt away form the engine, or are you looking for the transmission to bellhousing bolt pattern, which can be found here GM bellhousing to trans bolt pattern.
Old 04-19-2009, 05:34 PM
fast68's Avatar
likes chevy trucks & boobies
hi there what model trans we talking ?
i can get pics of measurements i have a th350 and a 700r4 setting out back on a crate i can do this for you with
but i need to know exactly what you mean and want
good luck!
Old 04-19-2009, 06:20 PM
powerrodsmike's Avatar
Wiki Edits: 161
Set a chevy bellhousing down on a table , engine side down and the measurement from the table to the trans mounting face is 6 5/16".In other words, the bellhousing is 6 .3125" from motor to trans.
The distance between trans mount bolts, (on the bottom of the rubber mount), is 1 1/2" .
On the engine test stand I built, I slotted the trans mount holes sideways as well as longways, so I could put any motor up on it..I made the rear mount stationary, and the motor mounts moveable so I could accommodate any length of engine /trans combination.
Hope this helps, later, mikey
ID:	37729   Click image for larger version
ID:	37730   Click image for larger version
ID:	37731   Click image for larger version
BE different....ACT normal.
Old 04-20-2009, 08:25 AM
6426yy's Avatar
Thanks guys
M&M I found that pic after I posted the question and I was really needing the depth from block to transmission mounting surface which powerrodsmike said is 6 5/16. This is good because I figured in 7 inches for the depth. My crossmember is fully adjustable so I can slide it back.
I have a bellhousing but it's still in the car in storage surrounded by junk. It's been there since I joined the service 11 years ago. I'll get to it someday!!!
Thanks again I'll post some pics after I get It finished.
Old 04-20-2009, 08:59 AM
Buy the CHEVY HIGH PERFORMANCE mag....May '09 edition. There is an article there entitled " Automatic Overdrives Spotters Guide" on page 38. Page 42 you will see the chart you're looking for. Orrrrrrr go to their web site www.chevyhighperformance.com and check it out on line. Good luck.
ZAPPER
Old 04-20-2009, 01:39 PM
6426yy's Avatar
Thanks Zapper but that doesn't give the depth for a manual transmission bellhousing. I've already finished the mounts for my stand so I'm forging ahead.
UAE huh, man that sucks, I drank plenty of beer in the Sand Box! I was on the Truman for her maiden voyage. VMFA 312 to be exact.
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 09:01 AM
Broken Bolt in a bellhousing CHEVY. monzter Transmission - Rearend 3 11-19-2008 10:29 PM
1936 chevy bellhousing bolt pattern powerrodsmike Transmission - Rearend 3 11-15-2008 07:27 PM
S10 5speed to a v8 chevy bellhousing ? fred stockberge Transmission - Rearend 8 06-27-2008 10:27 AM
Chevy Bellhousing #s help please 49T&C Transmission - Rearend 4 05-28-2004 02:07 PM
