chevy bellhousing and flywheel - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2006, 07:25 PM
I want to know what these go to? beelhousing#1 3840383#2 3849309 flywheel #1 3789788 #2 3973456. any information on these will be very helpful. thank you
Old 02-27-2006, 05:57 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
3840383, Cross references. Lookie HERE.
3849309, Nova, 10.5" clutch. Also crosses to another number, see link above.
3789788, no record found. I can't even cross reference this.
3973456, FLYWHEEL, no other records found. No cross reference for this either.
Old 02-27-2006, 08:20 AM
The 383 is for a 6cyl 1963-1967 chevyII
the 309 is for a 8cyl 1963-1967 chevyII
Carl
Old 02-28-2006, 01:24 PM
Chevy Bellhousings
Thanks For The Info. Someone Told Me These Wrer For A 409.thats What The Trans I Have Came With So I Was Wondering If The Flywheels Might Be For My 409.
Old 02-28-2006, 08:31 PM
Did 348's & 409's use the same flywheels as the small-blocks?
Old 03-01-2006, 02:05 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
From what I searched for, I found that the 348 and 409 were internally balanced like most of the Chevy engines, and they have the same crankshaft bolt pattern as the later engines, and the same bellhousing pattern as the later engines also.
So, yes the later stuff will work on the 348 and 409. Same as all straight 6's and Chevy built 200, 229, and 262 V-6's too. All of these physically interchange with each other.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
which bellhousing nick62877 Transmission - Rearend 7 06-29-2005 07:02 PM
Bellhousing and Flywheel question 79 Malibu327 Transmission - Rearend 5 06-28-2004 05:21 PM
Chevy Bellhousing #s help please 49T&C Transmission - Rearend 4 05-28-2004 01:07 PM
Buick V8 to Chevy trans Smonska Transmission - Rearend 7 04-12-2003 03:58 AM
