Chevy Bellhousing pattern
Does anybody has a diagram or blueprints for the bellhousing pattern of the chevy motors/trans?
I need to make an adaptor plate to fit a TH400 behind a Mercedes Benz 352 inline six diesel engine that will be transplanted into my chevy C30 dually pickup. I have no clue where is the input shaft centerline in the bellhousing, this will be very useful to make both parts mate perfectly. Thanks Augusto. |
I have a CAD file for a sbc at home. I will need to check if it denotes the bolt pattern (do not remember offhand).
Lonestar,
Please check your PM Thanks Augusto. |
you should not bolt the converter to a solid clutch flywheel, you must use a flexplate, otherwise the solid connection could damage the tranny's pump. are you thinking in putting a Toyota 13B diesel engine into a chevy pickup? I'm planning that also for a friend's C1500. Augusto. |
Vega,
so you're thinking of bolting a TH400 to a 22R, I would say that is no a good idea, the 22R has not enough low end torque to work with the already low first gear of the TH400, your best bet for the toy is the AISIN-WARNER 3 speed automatic used OEM by toyota and Volvo, this tranny has the rigth gear ratio, the correct bellhousing pattern ( removable ) and a small high stall converter, also it fits manual bellhousings from toyota in case you come across one from other manufacturer, and finally is very small and ligth weigth. Augusto. |
| Chevy truck 5 inch wheel pattern to 4 .75 | musky2 | Suspension - Brakes - Steering | 1 | 05-12-2006 07:23 AM |
| who knows about chevy blue engine paint? | doechsle | Engine | 2 | 03-31-2006 07:28 PM |
| Transfer case - NP 203 - 205 | jrm123180 | Transmission - Rearend | 2 | 03-24-2006 07:36 AM |
| chevy bellhousing and flywheel | fastjoe21 | Transmission - Rearend | 5 | 03-01-2006 02:05 AM |
| 28 Sedan Chop and Channel Ford or Chevy? | JLutz | General Rodding Tech | 5 | 02-08-2006 05:51 AM |
