I would just raise the compression ratio to around 9.5:1, and use a RV cam, such as the comp 268H series which reads, "if your doing heavy towing with a big block this is the cam you want" I would also add a edelbrock performer intake or the like. you need lots of torque to move a motor home, and these 2 additions along with a K&N air filter and the best ignition upgrade you can afford will give your 454 a torque increase. I would just upgrade the HEI with a hotter coil and matching module, use a brass terminal cap and use spiral core spark plug wires. You can also add headers and a decent exhaust system with crossover pipe to give it more torque, this will also likely help to increase mileage.
Might also look at an MSD box. This will give you some added throttle response, power, and ecomony at the 3000 and below RPM range.
Bringing history and technology together. |
