chevy blazer transmission shifter mod - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2012, 03:54 PM
Hi Guys,
I m trying to go with an automatic floor shifter for my blazer eliminating my column.
Would anyone be able to tell me what sort of mods I need to do for this conversion and also if there are any consoles i could use to make it look decent.
Appreciate your tips.
Old 06-13-2012, 08:44 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
b&m
B&M makes a bolt on shifter. You just bolt it to the floor. Drill one hole in front of the shifter assembly for the cable. Comes with a shifter cover and all the hardware necessary for different makes of cars.
Old 06-15-2012, 09:23 AM
Pull the shifter and console from another donor Blazer/Jimmy/Bravada. Some came stock with floor shifters.
http://item.mobileweb.ebay.com/viewi...id=60526626756
Old 06-15-2012, 12:50 PM
Thank you bracketeer/
Old 06-15-2012, 12:52 PM
Thanx for the tip midnightblu.
GM T-5 transmission short shifter? Highball Transmission - Rearend 0 04-20-2011 08:28 PM
modifying a 74 Blazer's transmission and transfer case Travelling_Teacher Transmission - Rearend 3 08-02-2010 11:21 AM
blazer transmission slipping ricksautorestoration Transmission - Rearend 2 08-04-2006 10:34 PM
Transmission/shifter matchup Pcr21688 Transmission - Rearend 2 12-24-2005 05:05 AM
1985 Blazer Transmission Leak daleraby Transmission - Rearend 12 06-06-2003 11:00 PM
