chevy block cast numbers - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2013, 03:08 PM
jwc jwc is offline
I have a sb chevy block full circle rear main that has no stamped id numbers or letters. on the drivers side of the block between the freeze plugs 099 is cast into the block and on the bellhousing flange there are these letters and numbers co 5.7lt gm sg1 can anyone tell me what I have? jwc
Old 04-10-2013, 05:19 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
No numbers stamped on the pad in front of the passenger side head, on the block ledge? Also, what are the six digits cast into the top bell housing mount area on the drivers side?
Semper Fi
Old 04-10-2013, 10:37 PM
jwc jwc is offline
sb chevy block cast numbers
that is my problem there are no stamped in numbers or letters. just 099 cast into the drivers side between the freeze plugs and the following cast numbers on the bellhousing lip co 5.7 lg gm sg1 it is a newer block with the full cicle rear main seal. I have not found anything as yet looks like I will be taking her apart to see what I have got. jwc
Old 04-11-2013, 05:20 AM
bondo's Avatar
Ayuh,.... It's a late model 350, What exactly are ya tryin' to find out,..??
Old 04-11-2013, 06:24 AM
jwc jwc is offline
anything I can like the year, what in came in, horse power, and anything else. did you find the casting numbers/letters? thanks for the quick reply, jwc
Need help with Chevy block numbers casper327 Engine 2 05-01-2009 12:48 PM
small block chevy ID numbers Camaro Rog Engine 3 01-29-2007 09:43 PM
chevy block identifying numbers JustinHebel Engine 2 09-23-2006 08:08 AM
chevy people-decode cast & stamped engine ID numbers BOWTIE JIM Engine 1 08-11-2006 12:49 PM
Thought on the following cast numbers, chevy v8 esears Engine 1 09-07-2003 04:35 PM
