Chevy block interchangeable with Pontiac / Olds/ Buick - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2002, 09:38 PM
Post Chevy block interchangeable with Pontiac / Olds/ Buick
It's been a few years since I was into older cars (be patient with us old geezers).
Years ago Chevy blocks were not interchangeable with Pontiac / Olds / Buick (POB). I have been told that some time in the 1990's POB adopted the small block casting of the chevy small block.
If this is so: Can a late model (1997) Pontiac small block engine interchange with an older 60's small block Chevy engine?
Thanks,
Jack.....
Old 04-12-2002, 12:42 AM
New Member
Post
i believe so, if it;s the gm LS1. lots of guys do it cause the new 350's are smokin'. if anything needs to be done it might be a slight adjustment of the engine mounts but if its a small block for a small block then you should be fine.
it's all good as long it's not a Honda
Old 04-12-2002, 02:06 AM
New Member
Post
What GM did was go to a corporate belhousing pattern. You will still need to deal with engine mounting positions, flywheel spacing, and exhaust clearances. Some GM makes did use the chev engines though. Unless GM has done something recently, the only difference is that the automatic transmissions were drilled for 2 bolt patterns, one being chev and the other whatever GM brand it was going in. A late Pontiac engine will not fit an old chev trans, but an old chev engine will bolt to a late pontiac trans.
Old 04-12-2002, 04:12 AM
Tom Tom is offline
Post
in 1978 buick stopped production of all V8s in1982 pontiac did the same that left GM with two basic engines left the smallblock chevy and olds and these engines became corporate,meaning if you bought any GM car with a V8 it was either olds or chevy so the first thing you have to know is which engine it is(olds came in chevys and visa versa)in 1987 the chevy heads changed to a slightly different intake bolt pattern and all V8 engines got roller cams(chevy and olds)chevy got center bolt valve covers,in 92 corvette came out with a mercury marine engine in the LT5 this engine went into camaros firebirds and impala ss also(they said it was a lotus but merc marine designed it)tranny bolt patterns are different between olds and chevy. the chevy block is still the same as it was long ago and interchanges will work if you pay attention to parts combinations
Old 04-20-2011, 02:55 AM
69copo
i believe the with the ls1 the trans am and camaro shared the same engine, with a different bolt pattern than the lt1 and back,the trans am and the camero shared the chevy engine for several years.but in the late 70s,early 80s they had a dual bolt pattern to fit all gms. i dont believe they were actual 350s.i think they were metric 250s i think. they had a lot of trouble with them, ive put a lots of 350s in there place a direct bolt in.
Old 04-20-2011, 03:55 AM
327NUT's Avatar
Hey Copo....this post is 9 years old, I see you're new, always look at the date.......we've all been burned the same way.
Old 04-20-2011, 11:02 AM
69copo
why dont they take the old ones off. i feel like a fool, thank you very much for telling me this. chat with you soon.
Old 04-20-2011, 01:31 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Don't feel that way, plus, if there are useable tidbits added it's a plus; they're kept here as part of the database and search functions I believe, that database is huge.
Welcome to the board.
Old 04-20-2011, 02:45 PM
Thanks,
Jack.....
A 1997 small block V8 would be a Chevy casting with Chevy bolt patterns. An older SBC should interchange without issue unless you cross the 1986 line where the engines converted from 2 to 1 piece rear seals. Because of this they type rear seal dictates the flywheel or flexplate because of a change to a smaller crank flange bolt circle on the one piece seal engines, the clutch or torque converter bolt patterns are the same on both sides of this divide.
Bogie
Old 04-20-2011, 07:26 PM
LATECH's Avatar
X2 bogie. Theres nothing Pontiac about an LS anything
Old 04-20-2011, 08:16 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A '97 Pontiac w/a 'SBC' engine would have been the Gen II LT-type.
