Chevy bolt pattern machining - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2010, 07:47 PM
Hi guys, Can anyone tell me how to figure a 4 3/4 bolt pattern when drilling different hubs? A friend of mine wants to change an early Chevy six bolt to a 4 3/4 five bolt. How does the machine shop set up on this? Thanks in advance, Rod
Old 10-26-2010, 07:59 PM
SSedan64's Avatar
Machine Shop uses an Indexing Head. This can be done on a Milling machine or Lathe.
Check some of these Google links for How to & making your own Index plates etc.. May even find a YouTube Vid
http://www.google.com/#hl=en&expIds=...510c6acf0fe428
How To Measure Wheel Patterns
http://members.cox.net/completevalue...l#HOWTOMEASURE
http://members.cox.net/completevalue/wheelpat.html
Old 11-12-2010, 08:46 PM
Thanks
Hey SSedan64, thanks for the info. I hadn't been on here in awhile. I'll check out those websites. Thanks again, Rod
Old 11-12-2010, 09:31 PM
I've never understood how the 5 lug measurement can be exactly accurate. Not that I'm arguing that it is wrong. I can see the even lug patterns, but it seems to me that the actual measurement on the 5 lug pattern would somewhat depend on the size of the bolts. If you had ridiculously large bolts, say 1", would that not change the measurement, the way we do it? What am I missing?
Old 11-13-2010, 05:23 AM
BOBCRMAN@aol.com's Avatar
The center location of a stud in a 4 3/4" bolt pattern is still the same. No matter what the stud diameter is..
Old 11-13-2010, 06:31 AM
Wiki Edits: 27
bolt circle measurement
The second link does not give you and accurate measurement, just close enough the check at the wrecking yard or swap meet. When programing the CNC you use the actual circle dimension , A 5 on 4 3/4 you use the actual 4.75 in, diameter dimension then divide the circumfence into 5 equal segments.
Old 11-13-2010, 09:01 AM
Will I ever get it done?
Last journal entry: Hood
Just to make it perfectly clear:
360 degrees divided by 5 equal 72 degrees. After drilling the first hole on the 4.750" circle, you rotate the axle flange 72 degrees and drill the next hole. Three more times and you have all 5 holes evenly spaced.
Old 11-13-2010, 01:22 PM
So I'm not wrong then. That method to check bolt pattern on a 5 lug is an approximation. Thank you.
Old 11-13-2010, 01:24 PM
Actually, you are very correct as far as the popular "approximation" measurement goes. The diameter of the studs will change the measurement, which is why this is only an approximation. A lot of people don't understand this.
Old 11-14-2010, 07:48 PM
Thanks
Hey guys, Thanks for all the neat posts and conversation. That gets me down the road. Thanks again, Rod
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
chevy camaro vs chevy pickup bolt pattern old fords Transmission - Rearend 2 09-19-2008 06:07 PM
Chevy 350 Crankshaft bolt removal 75gmck25 Engine 11 03-14-2008 06:27 AM
bolt pattern changing jniolon Body - Exterior 6 08-01-2005 01:02 PM
12 bolt Chevy truck pinion question Gametech Transmission - Rearend 9 03-09-2004 05:02 PM
