Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - chevy c10 door handle interior removal
Old 06-30-2010, 12:21 AM
matt167 matt167 is offline
Wiki Edits: 31
with a door handle remover ( $5-10 ).. push the door panel in, and push the remover into the shaft that is behind there.. it is supposto release the clip enough to allow you to pull off the handle, but I never have that luck.. I usually give it a little tap and a twist and it'll release the clip fully
