Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - chevy c10 door handle interior removal
Old 06-30-2010, 07:14 PM
66GMC's Avatar
66GMC 66GMC is offline
Get in, sit down, hang on
Last journal entry: Cab Removal
This works in a pinch, if you aren't able to find the correct tool.
I've used a hacksaw blade, with a V-shaped cut from the edge to the center of the hole. I also ground off the teeth so that they wouldn't damage the upholstery. Bend the tang just slightly so that it will engage the clip.
Edit:
There are supposed to be two pictures uploaded, but I only see one.
I'm sure you get the idea...
