chevy c10 door handle interior removal
im pretty new at this but i need to know how to remove the door panels off of my truck, but i dont want to damage it, the problem i was having was the interior door handle.. how do i remove it???
with a door handle remover ( $5-10 ).. push the door panel in, and push the remover into the shaft that is behind there.. it is supposto release the clip enough to allow you to pull off the handle, but I never have that luck.. I usually give it a little tap and a twist and it'll release the clip fully
oh ok cool... thanks.. so could i also jst use a flathead screw driver?? i dnt mind paying the lil bit of money but if i could save it i will...what do you think???
the clip needs to be released from both sides, so it would be very hard to use a screwdriver.. you will find the tool in the Help section of most any auto parts store, for about $5.. Harbor freight sells them for a dollar or 2, or you can get the entire 'kit' from them for like $10, which will have windshield and trim tools also
There are all kinds of tools to remove these GM "Jesus" clips, here are just some of them. The best one and easiest to use is the Lisle 35200. The black one second from the top has a place on the raised end to push the clip back into the door handle, but you can do it easily with your thumb nail. You push the clip back into the door handle and then just push it back on the post and the clip will seat.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
This works in a pinch, if you aren't able to find the correct tool.
I've used a hacksaw blade, with a V-shaped cut from the edge to the center of the hole. I also ground off the teeth so that they wouldn't damage the upholstery. Bend the tang just slightly so that it will engage the clip. Edit: There are supposed to be two pictures uploaded, but I only see one. I'm sure you get the idea... Last edited by 66GMC; 06-30-2010 at 07:18 PM. Reason: Only one pic uploaded? |
i like the rag trick so obvious and ingenious
i cant wait to try it out in the morning! i cant believe ive never come across it over all these years from an old timer or something wow... nice! |
Rag works perfect Dan.
I can't tell you how many 55-57 Chevy's we robbed door handles and window cranks from in wrecking yards back in the day. My parents garage was literally full of various 55-57 stuff. Dad cleaned it all all out when I was away in the military...never forgave him for that .Vince |
If you would have actually read what I said, you'd know I didn't say your method doesn't work, I said the clip doesn't stick out like you have it pictured. At least they don't on the four Chevies I own. I'm sure you can get the clip out with your method, but you can't catch the back of the clip, you'd have to catch one of the points that stick out on the side, just like every other tool and every other method does. I'm sure glad you didn't take what I said wrong and over react.
I'm sure the rag method works too, I didn't say that doesn't work either.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ Last edited by DanTwoLakes; 07-03-2010 at 06:49 AM. |
| Recent Interior posts with photos |
| 64-66 Chevy C10 Axle Information And Possible Swap | BowTiePride | Transmission - Rearend | 3 | 07-02-2009 09:44 AM |
| 1966 Chevy Stepside C10 | Mike Van Pelt | Introduce Yourself | 5 | 03-06-2008 09:30 AM |
| headers for a sbc in a '65 chevy c10? | Woogeroo | Engine | 6 | 04-22-2006 10:53 PM |
| reverse lights ideas for '65 chevy c10 lwb stepside? | Woogeroo | Electrical | 6 | 04-06-2006 07:33 AM |
| 1978 CHEVY C10 | reggiesr | Transmission - Rearend | 0 | 10-09-2001 06:20 AM |
