Chevy C6500 truck with 454 engine install distributor with cam sensor - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 01-22-2012, 01:06 PM
How to install distribuotr with cam sensor into 454 Chevy engine to be in time with crank sensor?
Old 01-22-2012, 03:30 PM
LATECH's Avatar
Last journal entry: New Gas Tank
Is that the plastic distributor, with the hold down that only allows the distributor to go in one posistion?
Old 01-22-2012, 04:16 PM
Yes.
The only thing this unit does is drive the oil pump and send signal to computer where cam is located.
Old 01-22-2012, 04:51 PM
LATECH's Avatar
IIRC there are no timing marks on the balancer, just 3 or 4 little cuts in the front edge.
What you need to do is turn the engine by hand with a socket wrench on the crank bolt, untill you get tdc #1 compression stroke.
Being there is no timing marks you have to rely on your expertise to gauge TDC through the spark plug hole.Then if you can put on a timing tape, back it up to 14 degrees BTDC.
At that point you are ready for the dizzy.If you look real close at the dizzy, where the cap touches the edge at the place it mounts, there is a number 8.
You want to drop the dizzy in the hole and end up with the rotor aiming at that number.
Now the 14 degrees BTDC may be hard to get to, but one of the little cuts in the balancer should be at the bottom where you can see it.I think that is 14 degrees when it is straight up and down, IIRC. Been several months since I did the last dizzy gear change and set one up.
Now when you get done, If it throws a code p1345, then you need to re learn the cam/crank angle. If the data stream shows that you are 7-13 degrees BTDC on the cam sync pulse timing then it is timed correctly and all you need to do is perform the relearn according to the scanner instructions.
Old 01-22-2012, 06:09 PM
Chevy C6500 truck with 454 engine.......
Thanks I will try this. Does the number 8 on the rotor need to match number 8 on the body of the dizzy?
Old 01-22-2012, 06:14 PM
LATECH's Avatar
No. Put the rotor at the little number 8 on the dizzy housing. Dont pay any attention to the firing order.Be sure when it is tightened down the rotor points at that little number 8. The 8 is to reference the dizzy as used in the 8 cylinder. Some of those dizzys had a 6 and an 8, and could be used in either a 6 or 8 cylinder, and were marked for reference accordingly.
Old 01-23-2012, 08:08 PM
Chevy C6500 truck with 454.....
At what point on the rotor is considered the pointer that needs to be aligned with the #8 on the dizzy housing? My counterblancer does have degree marks.
Recent Modern Electronic Engines posts with photos
Mustang II IFS Install in 57 Chevy Truck mestes Suspension - Brakes - Steering 7 01-24-2012 08:12 AM
1978 chevy c6500 (help) jeff lex Engine 1 01-03-2011 07:53 AM
Install a 350 or 4.3 in a 1954 Chevy Truck? knothead Engine 8 08-15-2007 11:16 AM
Th400 electronic speedometer / speed sensor Chevy truck Twistedwrench Transmission - Rearend 2 08-05-2006 10:43 PM
94 chevy 305 distributor install warhorse General Rodding Tech 2 08-18-2003 06:00 PM
