chevy caliper size - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2008, 08:30 AM
Marcel
Last journal entry: Choo-choo town
chevy caliper size
Is the size of the caliper determined by the piston size (or cup size) in the caliper?
Old 02-24-2008, 06:27 PM
powerrodsmike's Avatar
Wiki Edits: 161
Yes. Measure the piston below the dust seal, as the part that protrudes is usually smaller that the piston itself.
Later, mikey
BE different....ACT normal.
Exhaust Diameter Formula ChevelleSS_LS6 Engine 11 04-27-2012 09:21 PM
87 Lincoln Rear Caliper Banjo Bolt Size? sonicweb Suspension - Brakes - Steering 2 08-30-2006 01:00 PM
full size chevy truck cv axle install SSon18s Transmission - Rearend 3 04-10-2006 05:43 PM
what size valves? 305 chevy shane7643701 Engine 7 05-27-2003 11:37 PM
replace wing windows with full size 57 chevy pu jim shorts Body - Exterior 1 05-26-2003 02:44 AM
