Chevy Caprice steering column work - Rack Kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2006, 11:08 AM
ViperMonster800's Avatar
Caprice/Camaro/BMW
My Chevy broke last week. I go to turn the key and it doesn't start but the lights turn on as if it was starting. THE STARTER IS FINE, I know that much. While I have the key turned, I had to jiggle the steering column (already loose) and it would connect. I did that for almost a week (jiggling).
Then the race or sector gear (piece that holds the rod) broke. The most critical part in my steering column... to start the car. I waited 2 hours for my brother to show up with a steering wheel puller so I could take it apart and start it with a pair of pliers.
I'm ordering the "GM Rack Kit" that comes with the piece I need but I don't know how to put it on. I have yet to look in my shop manual (just dawned on to me) but I'll do that after I come home from work. I just need to know how to install it. Anybodys and everybodys help is always greatly appreciated.
Old 05-25-2006, 10:00 PM
I would just install another column ... less expensive most likely and easy to do ...
Neglected problems ... ALWAYS gets worse ...
Old 05-26-2006, 07:01 AM
Caprice/Camaro/BMW
I was thinking about that but I didn't want to spend more than $100 fixing a simple starting problem. Granted it would fix my shaky/loose steering column and give me back my wipers and cruise control but I'd rather do it the mechanic's way and rebuild it piece by piece.
Old 05-26-2006, 08:08 AM
broke 85 caprice column
install a light switch across the solonoid an call it good
Old 05-26-2006, 02:13 PM
This might help. GM used the same column for decades. Just about all of them have problems. I don't think swapping in another used one is a good solution.
http://buickperformance.com/tiltstee...lumnwobble.htm
Old 05-26-2006, 04:12 PM
I was NOT going to put a worn out one in it ... he already has one of those ...
Plenty of decent, not worn out columns available ... at least in my area ... with just a little looking ...
Old 05-26-2006, 08:57 PM
...I don't think I have ever come across one that wasn't bad
I kinda like that the lock cylinder is bad on my S10...I can start it and take the key out
Old 06-04-2006, 03:01 PM
Caprice/Camaro/BMW
Same thing in my wagon and Camaro. THANK YOU SO MUCH ON THAT STEERING COLUMN WEBSITE!! THAT IS EXACTLY WHAT I WAS LOOKING FOR!! Now all I got to do is get a pivot pin removal tool... and then I can finish. My tilt steering repair kit came in the mail yesterday from eBay for $30 total... better than $62 + tax from the dealer.
THANK YOU SO MUCH!!!
Old 06-04-2006, 04:43 PM
I have always just used a slide hammer and a machine screw (I think it is a #10 ). Be careful with the driver side...I almost took out my window when it finally came out.
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 10 05-13-2012 06:07 PM
Steering Column Wiring loiselle Electrical 3 05-16-2006 10:08 PM
Rack & Pinion Steering on a Chevy C-20 Suspension? Dusty82 Suspension - Brakes - Steering 3 03-01-2005 09:15 AM
MustangII Steering Wheel on Chevy Column smoran Interior 2 05-05-2002 08:37 AM
Chevy Tilt Steering Column James Groves Suspension - Brakes - Steering 1 11-20-2001 04:12 PM
