Chevy Carrier Series - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2008, 02:52 PM
MI2600's Avatar
Member# 3287
A friend has a posi Chevy carrier. He believes it's a 3-series because the flange (for lack of a better term) that the ring gear bolts to is the same thickness as a 3.73 rear he has.
How can you determine which series you have? Casting #? Some other method?
Old 02-12-2008, 09:53 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
If its an 8.5" 10 bolt clutch posi, it will have big numbers cast on it either 888 or 999. 888 is for 2.73 and up, 999 is for less than 2.73
Old 02-13-2008, 12:13 AM
Some of the 8.5" carriers have 410409 or 410408 cast into them. The -408 is series 3 (for 2.73 & higher ratios), and the -409 is series 2.
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 07:43 PM
55 chevy truck - 2nd series 1stproject Introduce Yourself 1 12-05-2007 09:51 PM
2 Series Carrier (posi) gpeak Transmission - Rearend 1 03-09-2004 06:10 PM
Dana series 3 carrier in an old Chevy housing PrimeMover Transmission - Rearend 0 04-28-2003 10:25 AM
Chevy 10 Bolt carrier megmar Transmission - Rearend 1 07-07-2002 05:50 AM
