Chevy casting manuf. date numbers - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2007, 04:27 PM
Can anyone tell me where to find information on '57 chevy 283 casting manuf. date numbers, or how to interpet the casting dates? Does the letters start with A for Jan. etc.?
Old 07-15-2007, 07:23 PM
MI2600's Avatar
Member# 3287
Yes, they start with "A" and continue, except for "I". The next digit(s) should be the day and the last digit(s) are the year.
Old 07-15-2007, 07:45 PM
WDCreech's Avatar
Grumpy Old Goat Herder
I'm into Pontiacs, but I think Chevy does it the same. Usually four digits, starting with a letter. It's like you said, A for January, B for February, etc. The next two digits are for the day of the month. (if there are only two numbers after the letter, the first would be the date) the last number would be the last number of the year. If Chevy did everything like Pontiac, if the first letter is a G (July) or later, it would have been manufactured for the next model year. ala, G167 would have been a 58, 68, or 78 etc.
Hope this doesn't confuse you too much and I hope it helps.
ID:	22759   Click image for larger version
ID:	22760   Click image for larger version
ID:	22761   Click image for larger version
Chevy 250 casting date strummin67 Hotrodding Basics 4 10-17-2006 03:28 PM
casting numbers blf55 Engine 3 12-31-2004 09:45 PM
Casting numbers for BBC GM Rect. port alu. heads sune Engine 0 05-11-2004 04:21 AM
casting numbers ??? jackyandjoe Engine 5 07-01-2003 05:11 AM
Can't Find Casting Date on 12-bolt PrimaDude Transmission - Rearend 0 03-11-2003 07:25 PM
