Chevy Cavalier PS for '49-'51 Ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2007, 01:45 PM
I have a 1950 Ford that I would like to convert to power steering without going the Volvo route with all the expense that entails. I have heard that a Chevy Cavalier rack and pinion steering can be used on the '49-'51 Ford cars. Anybody done one of these conversions, and can you provide technical data like year of rack, tie rod ends, mounting points, problems encountered, and other such info?
Also, has anyone used the GM Saginaw boxes and, if so, could you provide the same info as above?
Any help would be appreciated.
Old 01-25-2007, 02:01 PM
60tbirdrick's Avatar
Sacred Steel
Last journal entry: The dash
Fatman Fabrications sells a rack & pinion kit. I believe it uses an 89-94 Cavalier unit. I am not sure how good it is but here is a little write up on one that someone else installed.
http://www.y-blocksforever.com/tech/html/r_p.html I know this one is for the mid fifties Ford but they do have kits for 49-51 that probably uses the same Cavalier unit.
If you go the Saginaw route, stay away from Gearheads Cruiser Products.
Old 01-25-2007, 03:42 PM
grandpaws 57's Avatar
"Don't need no V/8"-grandpaw
60tbirdrick was right
We both got burned by GEARHEADS CRUSIER PRODUCTS. I LIKE MY RACK.Check company reviews befor you buy.!!!!!!
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Ford 5.0 vs Chevy 5.0 1meancuda Engine 21 06-13-2006 08:57 PM
51 Chevy 2dr Hardtop Chop dsmith1279 Body - Exterior 9 12-24-2005 05:01 PM
ford truck bed trailer for my chevy good idea? IHAVECHEVYPARTS Engine 8 11-14-2002 02:08 AM
ford 302 on chevy 350 mounts topcat662 Engine 1 07-02-2002 11:41 PM
