chevy ci - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2005, 03:26 AM
steve t's Avatar
ex biker, now hotrodder
chevy ci
when did chevy do away with the 350ci, there trucks now have a 293 or 325ci
Old 10-30-2005, 05:53 AM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
I think they still use a 350 in the Corvette, I'm not 100% on that though. I think they went to the 5.3 in about 1999. And, as my brother-in-law said then, the 5.3 had more HP than the 5.7. Less cubes for more power? Who say's there's no replacement for displacement? J/K I'd still take a 350 any day....
In a while, Chet.
Old 10-30-2005, 06:11 AM
Will I ever get it done?
Last journal entry: Hood
I always thought the only replacement for cubic inches was rectangular dollars.
The 2006 Corvette is available with the 6 liter LS2 (366 cu. in.) or the 7 liter LS7 (427 cu. in.).
Old 10-30-2005, 06:47 AM
26 modified
The traditional 350(5.7) that you are thinking of was laid to rest in 1998,
although it lingered on in the silverado and sierra classics(the old body style),
suburbans and 1-ton commercial trucks for a couple years.The gen III started
being sold as its replacement in 99. Remember that the gen III small block is
also available in the Corvette and new Pontiac GTO as a 350(5.7). But it is
most popular as the truck engine in 4.8, 5.3 and 6.0 sizes. If you liked the old
ones, you'll love the new ones. Its still just an engine. More powerful and more efficient on cheaper gas. After market parts are becoming extremely
easy to find too. Im not a big fan of large front wheel drive cars but, the 5.3 V8 is impressive in the new Impala.
Old 10-30-2005, 07:04 AM
I did a little more checking. The 6 liter is actually a little less than 6 liter. 364 cu. in. by way of a 4" bore and a 3.62 stroke. 5.96 liter.
As far as I can tell, the 350 (5.7 liter) is no more. GM is using the Gen IV engines, the LS2 & LS7. 364 and 427 respectively.
The LS7 is a small block with a 4.125 bore and a 4 stroke.
Old 10-30-2005, 01:27 PM
Bluepen's Avatar
Just a firefighter
Last wiki edit: How to title a hot rod
Last journal entry: New rear rollpan installed
Wiki Edits: 2
I've got a '05 Chevy 3/4 ton 4X4 2500HD LS with a 6.0 liter in it and I'm impressed with it. Nice power and torque. Haven't needed the 4X4 part yet but I think it will be the same. Even with the 4X the mileage isn't that bad with it, 14 mpg in and around town. Highway is only around 16 to 16.5 mpg, that could be better.
David
Old 10-30-2005, 04:24 PM
DoubleVision's Avatar
Personally I`m not a fan of the new engines, they look like they were run through a trash compactor first.
Old 10-30-2005, 05:23 PM
smallblocker2's Avatar
L79 327 5SPD S10 '65GTO
The good old 350 Gen I smallblock, is still truckin away in fullsize vans, if I'm not mistaken.
Old 10-30-2005, 06:12 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
The new 5.7L is 346ci, not 350. But I'll forgive ya.
1997 in the Corvette, 1998 in the fbodies, and 99? in pickups/vans.
the largest of this family is the 496ci, available in the heavy duty pickups. It'd do a good job in a Chevelle with a cam better suited for the use.
Yea they look stupid, ugly coil packs on the valve cover and a cheesy plastic cover (well, Dodge Hemi has the same now) to cover the vaccum hoses and other garbage.
But they work, and do they work well... my Grandpa has an 01 Silverado Z71 with the 5.3 (325ci, think new 327) and it has some balls.
Old 10-30-2005, 06:14 PM
Think, completly diff. than old 327.
Old 10-30-2005, 07:33 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
The 496 is a big block, it is not part of the Gen III engine family.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
9" to chevy conversion bigiron Transmission - Rearend 4 10-11-2005 10:32 PM
Can you use a 1933 or 1935 Chevy transmission in a 1934 Chevy? mistermuscles Transmission - Rearend 0 07-18-2004 05:40 PM
Chevy sending unit in a Ford Tank AnD Engine 0 05-14-2003 04:34 PM
New Member Introduction - 48 Chevy Rodder 48 Chevy Rodder Hotrodders' Lounge 0 10-20-2001 03:04 AM
