Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy Crank Trigger Conversion
Old 08-23-2012, 01:09 PM
zanewomack zanewomack is offline
Ok fellas and gals if applicable. I am at the end of a sbc build and decided to try and run a stock fuel injection system. The piece that I am missing to the hole puzzle (minus hours of wire tracing) is the crank trigger/ position sensor. Here are the details.
The vehicle I am building is a 1993 sbc 5.7 liter throttle body set up with 4L60e. This engine is no more and Im removing the TBI set up. (dont want carb)
I built a 5.7 roller motor out of a 1995 vortech setup with aftermarket 190/62 cc heads and bored over .6. Stroke is stock and cam is a computer controlled safe cam.
I robbed a fuel injection system off of a 1998 K1500 suburban. It is the "spider" injection system. I am good with the electrical conversion?? I can not find an ugrade or after market crank trigger I can use to replace the stock trigger that normally comes with it.
Any help or direction would be greatly appreciated
