Chevy crankshaft bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2008, 05:31 PM
69DartGT's Avatar
Nieghbor is replacing the harmonic balancer on the 307 in his Camero, it did not have a bolt holding the balancer on is this possible for a 307 not to require a bolt.
Engine is still in the car and looking at the end of the crank with a mirror and flashlight it looks like either the old bolt was broken off way back when or it doesn't require one.
Ever heard of a 307 not using a bolt to hold the harmonic balancer on?
Old 03-29-2008, 06:17 PM
justold's Avatar
yes .
early sbc didn't require a bolt ,I don't recall what year they started to use a bolt .[a little help here ]
Old 03-29-2008, 08:15 PM
It's not strtictly a date thing.
I know that a '66 350HP 327 had a crankshaft bolt, but a '64 220HP 283 didn't. Maybe there was a time that only the "high perfromance" engines got them, then later, all did. Not sure.
JA
Old 03-29-2008, 10:54 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
I've seen pre 1970 chevy's 6 and V8's with no threads and press on balancers. These were all light duty trucks, or smaller cars.
Old 03-30-2008, 10:14 PM
MI2600's Avatar
Member# 3287
All of the 305s should have had bolts.
Old 03-30-2008, 11:05 PM
69DartGT's Avatar
Okay but this is a 307?
Old 03-30-2008, 11:18 PM
super_silent's Avatar
I have a 67, 327, 275 HP and it has no bolt either.
Old 04-26-2008, 04:01 PM
the 307 in my 71 el camino did not have a bolt on the crank. I took the balancer off to replace it. Now having trouble putting it on. I rented a kit to instal it; but none of the adapters fit. I had to get a bolt from the hardware store. It fits but I am weary of using my impact to screw it on.
Old 04-26-2008, 05:22 PM
Chevy dampers were/are a press fit. The finance people didn't think the cost of a bolt was warranted since it fit so tightly. Apparently GM's finance people drive Fords.
Anyway, bolts on the front damper as more than a hit and miss proposition is a fairly recent invention at GM.
307's are old enough to be in that period where more likely than not it's not. Even though the end of the crank is threaded. Bolts for this can be had at the parts store along with the appropropiate really thick washer. Make sure the threads are clean before running a bolt in there. If it takes a lot of force to pull the damper on with the bolt, carfully sand the inside of the damper hub and outside of the crank with a light oil and about 220 wet dry paper. Sand a little and retry, when it fits smoothly and snugly, you're there. If the end of the crank isn't threaded, then installation of the damper is a shop process with tools and a press. Never hammer on the damper and if making a home made press, allways apply force only on the hub.
If the damper fell off and there are no threads for a bolt in the crank, there will be an on-center tooling hole, this can be tapped to accept a bolt. Chevy typically uses a 7/16s 20 thread to the inch bolt for this.
Bogie
Old 04-26-2008, 05:31 PM
DeathRattle's Avatar
Some Punk Kid
My 72 or 73 (I forget which) 307 has the bolt. As oldbogie said do it the right way, dont beat it on.
Old 04-26-2008, 11:37 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
I just drilled & tapped my 68-307, didn't wanta have one of the OMFG days "if" it would decide to do the unthinkable. Easy to do & cheap insurance. Ya need a 3/16 drill bit to predrill a starter hole, then a 25/64ths drill bit & a fine thread 7/16ths - 20 tap...joe
Old 04-27-2008, 09:45 PM
I thought a 7/16 wouldn't fit my crank, but today I bought a tap and cleaned the threads. Then I got a crank bolt set from the parts store and it fit fine. I used a hardware store bolt to crank the balancer on with my 1/2" impact. It went on fine. I put the crank bolt and washer on over the pulley. The reason I changed the balancer was a "knock" that appeared just after I changed my intake over to an aluminum one. The car idles too fast now and doesn't want to kick down to slow idle. I will probably get the timing set in the next day or two. I hope it straightens out.
9" ford with chevy bolt pattern retired 56 Transmission - Rearend 4 02-17-2008 11:44 AM
8.5 10 Bolt Chevy Info Needed jsteve068 Transmission - Rearend 6 09-26-2005 05:09 PM
chevy lug bolt size? KNanthrup Transmission - Rearend 4 08-27-2005 10:41 PM
Chevy accesory bolt holes. Palmer Engine 1 02-08-2004 09:42 PM
307 chevy bolt on? Heathster Engine 7 01-10-2003 11:37 AM
