Chevy Distributor - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2005, 09:13 AM
New Member
Chevy Distributor
I have a stock Chevy distributor that I have put a Pertronix Point less control module in. So far I am not impressed with the product. I put a new one in 3 weeks ago an it has gone bad already. Can some one give me some suggestions on a good reliable after market distributor. I have limited space to the firewall so a small HEI would be needed. It's a 55 Bel Air.
Old 08-14-2005, 10:42 AM
When I was faced with the same problem..........worn out SBC distributor and very little room..I purchased a MSD distributor. It is HEI inside, with a vacuum advance and was the small size as the factory Chevrolet distributor.
My SBC 283 was in a 40 Ford coupe.....
Summit Racing had them.....about $250 .......complete ......and then I upgraded to a Blaster MSD coil.....about another $30........
Mileage improved, better starts and smoother running engine.......
Old 08-14-2005, 11:50 AM
Rhansen's Avatar
Footbraker
Exchange the pertronix for one that works. Comes with warranty right?
I have heard they have quality control issues but I know a couple people running them in points style early dist. with no troubles.
Old 08-15-2005, 08:33 PM
I'd try the warranty thing, too. If that doesn't work, check out http://davessmallbodyheis.com/
Old 08-16-2005, 07:01 AM
I had one go bad on my 63 econoline 6 it was the per I ignition stuck and went interminant which they claim does not happen only tow home
so when I wanted one in my wifes car I got the pertronx II it lasted 2 weeks and I picked her up and installed the points and drove it home got my money back, and installed a dura spark dist with a HEI modualte and a .5ohm coil from a ebay used porcshe bosh coil. Never has had a problem yet. Ed ke6bnl
Old 08-16-2005, 08:07 AM
Did you remove the ballast resistor from the ignition circuit as per instructions? You need 12 volts to the Petronix system as per all HEI types. I have been running one for years in my old Bronco and have one in my Bud's daughters"s 289 powered Stang. Of course Petronix may be falling on hard times when their parts are outsourced to 3rd world like all other companies.
Trees
Old 08-18-2005, 06:01 PM
Mustangsaly's Avatar
isn't a SBC in a Ford a Federal Offense or at least Illegal ?
J/K Ya
to me a Ford needs a Ford Motor & a Chevy needs Chevy Butt Just My Opinion (i know i know opinions are like *ss *oles and everyone has one, and all Stink)
just had to say it, i'm in one of them moods, You Know Mens PMS
Mustangsaly
setting points on sb chevy frackster66 Electrical 23 01-07-2014 06:50 PM
Ignition system info................ poncho62 Electrical 18 10-11-2008 11:10 PM
Chevy 305 distributor replacement? Steve-0321 Engine 1 03-11-2004 09:51 PM
I Need Help With 31/32? Chevy walt Hotrodders' Lounge 9 03-02-2004 07:42 AM
starting problems lori-due Electrical 11 11-18-2003 03:00 PM
