Chevy engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2005, 09:23 PM
Chevy engine
does anyone know the differences between the 265 & the 283 chevy engine, parts wise, i just bought a 57 chevy 210, but dont know the exact size engine. i found a serial # on the door, but can't fine a plate on the firewall that describes the car as far as color, size engine & ETC,
Thanks Bruce B.
Old 02-14-2005, 07:21 AM
poncho62's Avatar
Wiki Edits: 5
Moving this to the engine forum, you will get better responses there.
Old 02-14-2005, 07:35 AM
BOBCRMAN@aol.com's Avatar
Externally the same. Copy the cast in number on the belhousing behind the driver side head. Then go to www.Mortec.com
Old 02-14-2005, 08:25 AM
Not many 265s in 57 Chevys. Chevy copied Ford by using up all the left over prior year stuff in the early stages of new year production. Most of the 265 motors were gone before Christmas 56.
Trees
Old 02-14-2005, 08:51 AM
Check the bore...That's the only real difference between a 265 and a '57 283.
'58 and up 283's had provisions for side motor mounts. 265's and '57 283's didn't.
Also, check for the presence of an oil filter mount. Most, if not all 265's didn't have oil filters on the block.
JA
