Chevy Engine cradle to motor-mount, bolt size question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2011, 10:42 AM
Zeeb's Avatar
Have a V8 converted Mazda (old school SBC) using standard GM motor mounts. I obviously didn't sufficiently torque the bolts (one on each side) that fasten the mounts to the cradle, and I lost the bolts. Mounts are just resting on the cradle. Can anyone tell me the most likly bolt size/thread pitch for the missing bolts? Thank you!
Old 01-30-2011, 10:50 AM
The mobile view is crap
7/16" bolts just a stander pitch thread. Isn't it just a nut and bolt or are your mounts threaded?
Old 01-30-2011, 11:03 AM
Zeeb's Avatar
Having to use a mirror, and things are a bit out of alignment, but I'm sure I see threads. I don't see how I would have clearance to "back up" a fastner in any case.
Old 01-30-2011, 11:23 AM
Zeeb's Avatar
Found the answer on Granny's Speed Shop on-line instruction set for Mazda RX-7 V8 conversion. 7/16" x 1". Thanks
Old 01-20-2012, 10:44 AM
JERRY 47 FORD COUPE
your bolts 3/8 sae 1 inch 9/16 socket size you need 6. 47 ford
Old 01-20-2012, 10:47 AM
engineczar's Avatar
The threads on the block are 3/8-16
BSE Racing Engines
Old 01-20-2012, 01:04 PM
JERRY 47 FORD COUPE
47 Ford
Ok Good News
How much clearance should there be between motor mount and motor mount bolt? firstgear Hotrodding Basics 8 03-21-2013 09:10 PM
chevy motor mount question skull Engine 6 07-14-2010 09:21 AM
Should I increase motor mount size sooper Engine 4 12-16-2009 04:34 PM
what size bolt for trans mount to crossmember? 70Velle350 Transmission - Rearend 2 05-04-2008 05:52 PM
Chevy 350 engine swap motor mount question 78transam Engine 4 06-04-2007 05:57 PM
