Chevy engine ID, can anyone help id my 350 engine? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2006, 09:56 AM
Last journal entry: Air Cleaner
I purchased an engine. The seller (reliable friend w/some knowledge) said it came from a 71 chevy Truck that it is a 350ci 4 bolt mains. I have the numbers and have tried to make sense out of them but I am sent to 69 by the block casting number and cant find accurate information from the other number from the right front. Here they are
casting 3932386
Front right pad
19J141972 V1012FB
The websites I went to are all over the place and I am so confused, can anyone tell me what engine I have and what it was from? Thanks Ron
Old 09-13-2006, 10:27 AM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
Ron -- first check our Knowledge Base, we have a specific category devoted to Chevrolet engine technical specifications: General Motors Engine Technical Data.
If you can't find what you're looking for in there, I'm sure someone will be able to lend a hand.
Old 09-13-2006, 10:31 AM
poncho62's Avatar
Wiki Edits: 5
Generally, the casting numbers don't distinguish betwwen 2 and 4 bolt mains. The best way is to remove the pan and have a look.
You gotta realize that a 71 truck is 35 years old....a 69 engine could have been substituted years ago.
Ontario Rodders
Old 09-13-2006, 10:43 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I looked the block casting number up at Mortech.com and it showed to be a 69 it said it could be a 302 ( rare) or a 327 or a 350. It also showed it both ways 2 bolt and 4 bolt main.
Old 09-13-2006, 10:47 AM
casting 3932386
Front right pad
19J141972 V1012FB
My Prosis data base said
67-69 302
68-69 5.4 litre (327 I presume)
78-79 5.7 litre 350
as for four bolt, the only method I know for sure is,take off pan or try to look at main caps with front cover removed.
I also thought years ago that a block casting number ending in (010) was a four bolt, bought one from junk yard, paid 4-bolt price, a few years later I decided to use it , tore it down and it WAS NOT a four bolt. Lesson learned the hard way.
Old 09-13-2006, 10:54 AM
I appreciate the help.
I purchased it for a great price ($100) the guy said that it was running but not well. I want to rebuild it and I an not sure how much I need to know to purchase all the parts. I am going to start the tear down in a few weeks and if I need to replace piston rods or crank or any major components I want to make sure that I am getting the right ones. Seems to me it could be important.
Old 09-13-2006, 11:08 AM
Here they are...
casting 3932386
Front right pad
19J141972 V1012FB
1969 327 engine with
235Hp from a full size Chevrolet passenger car ...
Old 09-13-2006, 11:26 AM
Duece
I was kind of thinking the same thing. I have a Chilton's manual for 62 to 72 cars and the only place I could find the FB engine designator was on the 69 Corvette engine specs. I am a beginner at restorations and engine rebuilding. I have worked on my own cars all my life but this is my first restoration car. I am building a 66 Chevy II Nova. Thanks for your help.
Old 09-13-2006, 11:32 AM
poncho62's Avatar
Wiki Edits: 5
If that Nova is a standard tranny, you are going to have an issue with the clutch pivot. Nova blocks had a special boss on them for that. Just something to think about.
Ontario Rodders
Old 09-13-2006, 11:41 AM
straight 6 with pg tranny
I am removing a straight 6 with auto trans. I have available a turbo 350 that I am thinking will fit.
Old 09-13-2006, 11:42 AM
You can see the engine and the car
If you click on the project journal link to the right of this message.
Old 09-13-2006, 11:45 AM
poncho62's Avatar
Wiki Edits: 5
You have to remember too, that the Novas had a front sump pan and oil pickup....................Rear sump wont clear the stock steering arms.
Ontario Rodders
Old 09-13-2006, 11:47 AM
poncho62's Avatar
Wiki Edits: 5
If that is the engine, I have my doubts that it is a 4 bolt main............they had 4bbls on them. Of course, I may be wrong.
Ontario Rodders
Old 09-13-2006, 12:00 PM
4 bolt main
I agree. The casting number shows that if it is a 327 then it is a 2 bolt main the 327 did not appear to come in 4 bolt
302 and 350 showed both. 2 & 4.
I was able to find the casting number on several web sites. the other numbers from the front right are the ones that are confusing. I will take the oil pan off tonight and take a look. I will post a picture. I do appreciate the information you added about the oil pan and the trans.
Old 09-13-2006, 01:30 PM
Mustangsaly's Avatar
www.mortec.com says
3932386....302.....69....4...Z-28 Camaro
3932386....327.....69....2
3932386....350.....69....4
I guess you need to look up the crank #s to know the stroke, cause there all the same bore, crank #s or the stroke will let you know if its a 302 327 or a 350 look the crank #s up off the http://www.mortec.com/cranks.htm website.
Mustangsaly
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
350 engine greg arnswald Engine 1 05-21-2006 02:49 PM
engine timing- 350 chevy stinky jinx Engine 7 06-02-2004 11:00 AM
350 chevy engine buildup dran04u Engine 9 06-07-2003 06:39 PM
350 chevy engine we2nutsinahouse Engine 3 06-15-2002 06:45 PM
