Chevy engine swap info needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2007, 01:49 AM
can anyone tell me if the 305 V8 out of a 94 chevy 1/2 ton pickup can be replaced with a 350 out of my 84 chevy 1/2 ton pickup? just change intakes?
the 305 is throttle body, but I would just put that intake on the 355 right?
thanks in advance for any help
I also noticed that the oil filter location is a little different, would that matter?
I know it it is not allowed to be easy, right?
Old 12-31-2007, 02:28 AM
DoubleVision's Avatar
The flexplate would have to be changed since the 84 engine will be a 2 piece seal crank flange. The rest is pretty much a bolt up. However, you`ll need a 350 knock sensor, 350 injectors, and a ECM chip from a TBI truck that had a 350, otherwise it`ll run too lean. The TBI`s 4 center intake bolts are a different angle so you`d have to slot the intake with a die grinder or swap heads. Slotting the intake isn`t hard and is often done. If you plan to keep the serpentine belt arrangement and I certainly would, you`ll need to use the 305`s water pump.
Old 12-31-2007, 03:33 AM
i'll just use a new water pump, for the 305
Engine Swap - 64 Galaxie Billy Boy Engine 5 07-21-2005 02:49 PM
Engine Swap thundercatsteam Engine 4 02-10-2004 09:29 PM
55 chevy engine swap timrocket72 Engine 0 11-04-2003 09:33 PM
Engine swap 305 olds to a 350 chevy morbidmike Engine 6 10-19-2003 11:33 AM
engine swap need info brojohn Engine 1 05-24-2002 07:54 AM
