Chevy engine swap info needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2009, 02:00 PM
Would like information on installing a 350 chevy engine in a 54 chevy car?
Old 09-01-2009, 03:43 PM
Google it there's tons of info out there. I'm tail deep in 'gators and just don't have time right now, but I'm not trying to blow you off, it's that this is a super common swap. The process is pretty much the same for the years 1949 thru 1954. 1955 moves to an open drive shaft which is conversion you'll need to do, but it isn't difficult. Biggest things are engine and tranny mounts all of which is available http://www.spiderautomotive.com/transdapt4196.html
The biggest PIA is converting from 6 to 12 volts. You'll have to decide whether to replace everything electrical including the fuel sender and gauge or work out a split voltage system with some of the original stuff retained at 6 volts and the rest at 12VDC.
Bogie
Chevy 350 engine swap motor mount question 78transam Engine 4 06-04-2007 06:57 PM
engine swap needed joeguz Engine 4 02-01-2006 05:18 AM
1940 Chevy Coupe Engine Swap canyonclimber Engine 4 01-28-2006 03:45 PM
Need Help!!! 326 Swap with 350 Chevy Engine greg67 Engine 13 11-06-2003 12:44 PM
55 chevy engine swap timrocket72 Engine 0 11-04-2003 10:33 PM
