Chevy Fixed Yoke? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2008, 11:45 AM
Chevy Fixed Yoke?
What GM transmissions (SBC bolt pattern) were available with a fixed yoke? Anyone have any pictures, spec's, part #'s, links, etc.? Specifically I would like to know if any TH-350 ever came with a fixed yoke...or something of about the same size/weight. What would be other options that could be adapted with a mid-plate or bell-housing? Manual trans would also be acceptable as long as it is close ratio and not a granny low truck trans. It needs to be able to stand up to a stroked 4.3L V6.
Old 06-12-2008, 01:13 PM
Chevy Fixed Yoke?
400 turbo out of ambulances and heavy trucks is all i ever seen with the bolt type
Old 06-12-2008, 08:34 PM
th400 was the only stock GM one with a bolt on yoke, but a th350 could be modified for one, jeep guys have been doing something similar for years. Basic idea here (Hack N Tap ), then buddy up to your local driveline/machine shop .
Old 06-12-2008, 08:55 PM
I have seen that done on a transfer case, but never on a 2wd trans. I think there would be a problem not having a ball bearing in there (just the bushing).
Does anyone have any pictures of the th400 fixed yoke? Does it use a ball bearing?
Old 06-12-2008, 09:21 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
I took one out of a 79 GMC 3/4 once. TH 400. If you mean ball bearing on the output, instead of a bushing? This one was a bushing, and I can't believe GM would ever have had one with a ball/or/roller bearing.
Old 06-12-2008, 10:17 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
GM bolt on yoke for the t-400 uses a regular bushing in the tail housing.
The motor home t-400 with large parking brake device had ball bearing on the yoke.
There is a custom after market tail housing with ball bearings and fixed yoke that many off road racers use. It is quite expensive.
Old 06-12-2008, 11:43 PM
I guess I'm just too used to 4wd fixed yoke setups. I have seen the aftermarket TH400 assemblies. Yes they are very expensive. But I don't think anyone makes one for a TH350.
Was there ever any 2wd fixed yoke with a ball bearing from one of the big 3?
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
slip yoke doesn't (slip) on... markzepp820 Transmission - Rearend 14 04-29-2008 01:29 AM
T-400 yoke question sandwillys Transmission - Rearend 6 01-12-2008 07:59 AM
3 speed chevy yoke green53 Transmission - Rearend 0 11-13-2007 07:06 PM
