Chevy flooding problem. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2002, 07:13 PM
Post Chevy flooding problem.
Hi, I have a 73 chevy sb 400v8 4bolt 4barrel, in a 82 Suburban. My problem is only when you punch it, it gets going just fine and then the carb floods out some times. It doesnt do it under normal driving conditions. Does any one know if it would be a carb problem, or maybe a weak coil or something? I also noticed the gas sometimes runs onto the manifold out of the carb when it floods. If anyone can help I would be greatful.
Old 10-08-2002, 07:30 PM
Post
Float might be getting stuck, careful with that, I've a Camaro catch fire like that, flooded and stalled float stuck, he held gas pedal to the floor, pumped gas all over his manifold and bam his 406 was on fire.
Old 10-09-2002, 07:20 AM
Post
Maybe ill try replacing the float and rebuild the carb again. Thanks for your help.
Old 10-09-2002, 12:29 PM
New Member
Post
it could be the float.and it could be a broken or bent metering rod
Old 10-13-2002, 11:10 AM
Cool
It was the float! It was hitting the back of the bowl. The power and milage is back. Thanks for your help. Have to keep the old toys going.( The new ones suck)THANKS
Cool
