Chevy Flywheel Casting's
Anybody have a good website or two for flywheel casting numbers? I have seen tons of info on blocks, heads, etc. but what I need on flywheels.
Here is an aftermkt site. several http://www.pioneerautoinc.com/engcat.htm or http://www.nextag.com/chevy-camaro-f...on/stores-html
Hey I appreciate those websites but I am looking for something that has casting #'s for flywheels. I looked at what you gave me.
Some of the old GM part books list casting numbers. Look up part and in part discription it lists the cast #
Hey Jim, it looks like you have some good info. Here is the casting # on a flywheel that I have. 3973457N Any info let me know. Thanks
You likely have a Mercruiser 330 horsepower (boat) 454 externally balanced flywheel from what I found on that number. If so- the clutch surface will be painted as they only used 6 of the outer bolt holes to mount the drive to.
It would be fine to use in a vehicle with a manual transmission, just get the clutch surface cleaned up, not sure if the balance differences are the same or different for 400 small block and 454, or even the external balanced 350's for that matter, not much floating around here for that info, or on the net either. |
try here at the partstrain they have a lot of ***************** you can choose from.
Last edited by 68NovaSS; 01-16-2012 at 01:45 PM. Reason: Advertising. Please see: commercial posting guidelines. |
| List all of your cars HERE! | Carbed95GT | Hotrodders' Lounge | 289 | 11-09-2011 06:43 PM |
| 350 Chevy starter pinion to flywheel clearance | Bonehead4x4 | Electrical | 8 | 03-28-2009 03:49 PM |
| 350 HO Flywheel | m007gunit | Transmission - Rearend | 3 | 12-10-2007 12:29 AM |
| Flywheel for 89 Chevy 350? | shad88 | Transmission - Rearend | 4 | 05-01-2007 07:31 AM |
| 67 Chevy Flywheel Cover | jbersk | Transmission - Rearend | 1 | 05-31-2006 10:20 PM |
