We're winning the case!
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 06-21-2005, 07:21 PM
billszoo1 billszoo1 is offline
New Member
chevy flywheel R&R
can a flywheel be removed and replaced without moving transmission on a 70 chevelle 350c.i.w/350 turbo. cant do to much right now, recently had rotator cuff surgery and can barely raise right arm above my shoulder let alone push or lift anything (at all) with that arm. any ideas???thanks.
Old 06-21-2005, 07:34 PM
WakBordr7387's Avatar
WakBordr7387 WakBordr7387 is offline
Gone fishin'
WakBordr7387's barnstar
Wiki editor
Last wiki edit: Removing stuck fasteners
Wiki Edits: 2
There is no way to get the flywheel off without moving the tranny back. You have to remove the torque converter just to get the bolts off.
You could have somebody else do it for you, thats if you don't mind someone else working on your car for you.
Brad
Old 06-21-2005, 07:47 PM
New Member
R&R
thanks, thats what i was afraid of. guess ive got no choice if i want to drive it this summer.
Old 06-21-2005, 11:56 PM
jimfulco jimfulco is offline
If you can get the trans mounted securely on a jack, you may be able to move it far enough to the rear to get to the flexplate. If you try it, be sure you have something to keep the converter in the transmission, as it tends to want to slide forward, then fall on whichever of your body parts it can find.
Old 06-22-2005, 10:46 PM
Crosley's Avatar
Crosley Crosley is offline
Crosley's barnstar
Wiki editor
Last wiki edit: How to identify a Ford V8
Wiki Edits: 713
Some people use long studs in place of two lower bell housing bolts..... slide the trans ( on a tranny jack) back a bit to get a wrench on the flywheel bolts.
My opinion is you are so close to full tranny removal , I take the trans down & out ....... just me
At the Bonneville Salt Flats... 130mph is known as First gear ...............
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "chevy flywheel R&R"
9" to chevy conversion bigiron Transmission - Rearend 4 10-11-2005 10:32 PM
flywheel to convertor holes not lining up??? v8s10 Engine 8 06-01-2003 08:53 PM
Chevy sending unit in a Ford Tank AnD Engine 0 05-14-2003 04:34 PM
Buick V8 to Chevy trans Smonska Transmission - Rearend 7 04-12-2003 03:58 AM
Aluminum flywheel Camaro2Fast4u Transmission - Rearend 1 02-04-2003 09:17 PM
