My 67 came wth drum/drum originally, its an easy swap to do. I had a 72 chev PU 1/2 for parts and it was a bolt on. More than likely thats what was done to yours.
Rear leafs were standard in the GMC's and an option on chey's. |
i thought it might have been something like that also. i just kind of doubt that the guy that did it was capable and willing to do it. this truck isn't really a '67 chevy it's more along the lines of a mix'n match chevy. i'm also being thrown off decoding the vin, i found one site that says it's actually a '71, which could account for the frame i guess. if someone else wants to try the vin, here it is- KS1013726 this is what it is on my insurance. thanks for the help stea.
1967-1972 VIN Number Codes
Using the VIN you posted: KS1013726 The Model Number is located on the inside of the glove box door.) Example: C E 1 09 9 34 J 100001 Chassis Designation (1st digit) C = 4x2 K = 4x4 P = Forward Control Engine Deisgnation (2nd digit) E = V-8 Gas S = Six Cylinder Gas GVW Range (3rd Digit) 1 = 1/2 Ton 2 = 3/4 Ton 3 = 1 Ton Cab To Axle Dimension (4th Digit) 07 = 42"-47" 09 = 54"-59" 10 = 60"-65" 12 = 72"-77" 13 = 78"-83" 14 = 84"-89" 15 = 90"-95" Model Year (5th Digit) 7 - 1967 8 - 1968 9 - 1969 0 - 1970 1 - 1971 2 - 1972 Body and Brake (6th Digit) 02 = Flat Face Cowl 03 = Cab 04 = Stepside Pickup 05 = Panel 06 = Suburban 09 = Cab, Platform, and Stake Rack 12 = Windshield Cowl 16 = Suburban (Tail and Liftgate) 26 = Custom Suburban (Panel Rear Doors) 34 = Fleetside Pickup 35 = Foward Control (Square Front) 36 = Deluxe Suburban (Panel Rear Doors) 42 = Forward Control Chassis 45 = Forward Control Panel (Round Front) Assembly Plant A = Atlanta B = Baltimore F = Flint J = Janesville N = Norwood P = Pontiac (GM Truck) S = St. Louis T = Tarrytown Z = Fremont 1 = Oshawa, Ont., Can. Vehicle Serial Number 100001 = 1st Unit Built |
I'm not sure about Trucks but on passenger cars the vin will also be stamped on the frame somewhere , I know on Tri Fives it's on top of the frame just in front of the rear wheel opening . If you can find that and it matches your vin tag on the body - with the info M&M has posted - BINGO
im having a similar problem. someone gave me an engine and all i know is that it is an 82. the ID number is CB1161356. can anyone decode that or send me the decoding info for 80's frames. please and thank you
only the last half the vin code is on the truck frames
the serial code ppl dont seem to understand this concept on GM full size trucks: '70 was last year for 6 lug 1/2 ton and all were drum front all '71-up were disc front and all 2wd 1/2 ton were now 5 lug most gmc were leaf type G70 rear suspension and most chevy were coil trailing arm type rear suspension you either have a '71-up truck, or a '70 older converted to discs the frame rails on '73-up are a tiny hair wider than '72 older and also thicker feeling steel than '73-up i could tell the frame year group by seeing in person but i cant explain it on keyboard. if you look at the front control arms.... if the control arm shaft bushings are rubber then its a '73-up 1/2 ton front if they are old greaseable solid caps then its a '72 older 1/2 ton (or a 3/4 ton or 1 ton any year) the rear leaf spring hangers also differ from '72 to '73 but i cant explain it here.... have to see it myself .. if the wheel base is 131.5" then its a 73-up if its 127" then its a 72 older longbed anyways |
i know my frame is an 82 but what i want to know is, is it off of a GMC pickup or chevy pickup and what model, bed/cab size, and other things like that.
Frame Serial Number
I have a GMC or Chevy frame with this number on it:C42100152 on the left frame rail ahead of the uuper control arm. Any suggestions as to what this came from? 5 lug, front discs, rear leafs. Currently sitting under my customer's 58 3200 truck. He wants to do a 4 inch lift and I want to use spindles n springs up front. I don't want to play the guessing game with the frame and ordering parts. Thx gentlemen
