chevy fuel pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2013, 08:58 AM
chevy fuel pump
I have a 1962 willis truck with a 327 chevy engine , with a holley 650 on it , someone put an electric pump and tried to adjust pressure with a water valve .what I would like to know is there a chevy fuel pump made upside down to install onto its original position ? the reason is that the engine sits so far down in frame that original position is not possible
Old 11-10-2013, 10:19 AM
Banned
not sure if it will work ,you would have to match it to a chevy pump but an olds 350 pump is mount the way your looking for
Old 11-10-2013, 10:56 AM
ogre's Avatar
the 'Duracell Project'
you could put a fuel pressure regulator at the carb for an easy fix. jegs has a holley low pressure regulator for carbs
using a valve would only work for one flow setting at any other flow it would over pressure the carb or starve the carb
Old 11-10-2013, 11:28 AM
BOBCRMAN@aol.com's Avatar
How many times I've gotten returns on those olds pumps when they get installed like a chevy!!!
I really don't recall anything that will adapt, with an inverted diaphram, to a sbc.
Old 11-10-2013, 12:47 PM
techinspector1's Avatar
Wiki Edits: 326
What is in the way? The name of this forum is hotrodders. That's what we do. We eliminate stuff that's in the way, or bridge around it.
Old 11-11-2013, 01:37 PM
I'd go for the proper adjustable fuel pressure regulator. If the fuel pump you have works, I'd just do that. Regulators are pretty cheap.
Holley Fuel Pressure Regulators - Free Shipping on All Orders @ JEGS
Old 11-15-2013, 09:26 AM
buy a spare elec pump and stash it in your trunk. clean the fuel filters and get a proper regulator before you burn the thing down
Can an external electric fuel pump suck fuel through an in the tank fuel pump? v123 Engine 3 06-02-2013 01:42 PM
Chevy mechanical fuel pump moving TOO MUCH fuel? Torque454 Engine 1 11-04-2011 01:48 AM
95 gmc jimmy fuel pump won't shut off/fuel pump relay garystrosnider Electrical 7 10-28-2010 07:10 AM
TPI 350 fuel pump *VERSUS* a Multiport 2.8L fuel pump boneyard Buick Engine 8 06-04-2006 11:56 PM
TPI 350 fuel pump *VERSUS* a Multiport 2.8L fuel pump boneyard Buick Engine 0 03-18-2006 09:40 PM
