Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - chevy gear heads
Old 04-10-2002, 05:40 PM
1BAD80's Avatar
1BAD80 1BAD80 is offline
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
Why did you use 305 heads on a 350? they have less flow. The cam is probably to much lift and the valves are hitting the piston. Whatever you do dont crank the motor over until you find the problem. Bent valves or a cracked piston.Excessive ware on cam also.
Do the pistons have a valve relief cut into them?
Did you do a clay/ measure test for valve to piston gap?
Luv the smell of NITRO in the morning.
