Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - chevy gear heads
Old 04-11-2002, 05:17 PM
1BAD80's Avatar
1BAD80 1BAD80 is offline
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
HQ PETE is correct. Compcams come ground 4 degrees advanced, and if you advanced this cam it will crash. I'd recheck the cam timing. has all the info on cam timing, spring bind,anything on cams,heads, rocker angle.
Luv the smell of NITRO in the morning.
