Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - chevy gear heads
Old 04-11-2002, 09:30 PM
wrenchturner wrenchturner is offline
Red face
thanks you both was right on went back to timing chain rechecked dots found I was off dots was poorly visible just about needed a magnifying glass to see had some numbers next to it wasnt at the end of the teeth well that problem solved now Ive have bigger problems block has crack in it lucky I got another ready to go but I didnt really want to use it its set to go to a 383 have every thing for it exept some decent heads low on funds put on hold for another day dont want to cut corners on it like the other one just trying to get something going to hold me over till things change really appreciate the input back to the drawing board Thanks
