Chevy Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2010, 06:09 PM
Chevy Heads
I Got A Set Of Heads 354484 Which I Havent Found A Lot Of Info On,i Checked The #'s Again Found Info On 354434. Supposed To Be 307 Heads On My Mild 350. My Question Is One Head Has Square Exhaust Port And The Other Is Rectangular. What Up With Dat? Why Put 307 Heads On A 350 Anthow? Thanks Gary
Old 08-29-2010, 06:53 PM
DoubleVision's Avatar
354434.....75-79...262/267/305...60cc chambers
Some bolt them on 350`s to raise the compression ratio due to the small chambers or to build low end torque from the small runners and valves. If it`s performance your looking for I`d get rid of them.
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
Chevy Small Block Heads druss32 Engine 17 05-10-2006 08:35 PM
chevy heads desireable for the rebuild of a 400 for my 3/4 ton 86 2x4. nh32u Introduce Yourself 4 12-17-2005 06:31 PM
Questions about heads for 355 rebuilt chevy 77 Monte Engine 1 01-16-2005 05:47 PM
Chevy X heads? HemmiGremmie Engine 4 09-17-2004 11:37 AM
