chevy heads (3991492) ANY GOOD? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2011, 08:32 PM
vetteman2's Avatar
I just got a old 350 chevy motor with casting number (3900010). The heads are (3991492)
I wanna stick them on my 84 (305) chevy motor. Good Idea? The heads have the small little humps on the front with acc. holes.
Old 03-26-2011, 08:36 PM
there good! 202 intake 64cc heads but you will run into valve cyl wall interference with them on a 305.
and if you do manage to clear up the interference problem performance would suffer due to poor air flow between the valve and cyl/deck
Old 03-26-2011, 08:38 PM
BOBCRMAN@aol.com's Avatar
Also not compatible with unlead gas.
Old 03-26-2011, 10:40 PM
cool rockin daddy's Avatar
Better idea would to be rebuild the old 350 and ditch the 305
Old 03-27-2011, 11:16 PM
vetteman2's Avatar
thanks
what would happen if you ran em' with reg gas
Old 03-28-2011, 07:59 AM
lead was used as a lubricant in older cyl head on the valve seats.
all you need to do is take them to a machine shop and have hardened valve seats put in average cost $200
then your good for unleaded fuel
Old 03-28-2011, 08:30 AM
vetteman2's Avatar
ok
thanks
Old 03-28-2011, 08:38 AM
Banned
They're 64cc heads, so you'll need to heavily angle mill them to get decent compression, probably around .150" or so. If the seats are not too far sunk already you can get by without hardened inserts, but not with much spring pressure.
IMO you're better off going with a good set of used aftermarket heads, the 492's typically have excessive guide wear and if you need seats, a valve job, angle milling, etc. you're looking at $500+ in machine work in most cases.
Old 03-28-2011, 05:10 PM
Check intake valve to block clearance on a 305 bore.
Old 03-28-2011, 05:22 PM
i cant think of any small chev head with less than 58cc chambers going to 64cc would barely make a difference 9.4:1 would change to 9.0:1 not enough to justify machine work
Old 03-28-2011, 07:43 PM
ericnova72's Avatar
More for Less Racer
Find a compression ratio calculator you like online and start using it.
On the small bore 305, going from a 58cc head at 9.4-1 compression to a 64cc head results in the compression ratio dropping to 8.7-1. Thats a pretty big hit.
Old 03-28-2011, 08:38 PM
i took a shot in the dark as there is a ton of info missing to use a calculator correctly.
i thought that would be close enough not to get flamed
The good vs bad chevy vortec heads stevenf Engine 22 04-23-2012 05:52 PM
Any good feedback on 434 chevy heads johnnyThunders Engine 5 12-23-2010 10:02 AM
041 chevy heads....any good? Short_box Engine 9 08-14-2009 11:34 PM
3927185 chevy heads. Are they any good? JPEG_engines Engine 6 07-08-2006 12:40 PM
Chevy Heads/Dart 200cc 72CC 2.02/1.60 Head. Is this a good deal??? 89SDime Engine 1 02-01-2006 03:45 PM
