Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - chevy hei issues
  #16 (permalink)
Old 08-30-2012, 02:08 PM
clintondp clintondp is offline
im charging the battery this second. but i started disconnecting the alt an dizzy. which is where im starting . im jumping from battery to batt terminal hei then ive doscoonected the alt power lead . but before i try starting it ive found one funky thing. with key off the alt wire reads battery voltage ( normal) . power wire to hei has no voltage but set to ohms an i get a weak ohms reading from the lead to ground. hmmmmmm but i get battery voltage withkey on on hei wire. no burnt fuses? rediculous. must be why they used inline ones from factory.
