disconnected the alt. an ran stand alone 12v wire to batt terminal. nothin. had a god gm module i had tested . i had them test it close to 20 times to get it supa dupa hot to se if there was thermal break down. also tested coil . it tested good. im at complete odds . only thing i havent checked is to see if i have a groundd wire on the starter. but like i said i havent popped one fuse either so i dnt know how i could have a dead short an no burnt fuses. should i also disconnect the two wire harness from the alt too an try starting it? could all these symptoms now point to just going new plugs cap.rotor wires? i mean all that stuff is fresh an was working 6 days ago. i havent tested the cap to see if theresbreaks in the contacts but ive ohmd the wires an they test good. ugh i dnt know boys its getting sticky
