Chevy help - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2008, 08:56 AM
grapro's Avatar
Last journal entry: Out in the Sun
Chevy help
Got a little problem. A kid working for me has a 97 chevy pickup with a 5.7 vortec and he forgot to check his antifreeze and he cracked his block, As usual he is short of cash and I want to help him out. I've got a 350 which came out of a early 90's chev which has the different bolt style for a tbi or vortec style intake and was wondering if this motor would work as a short block with his intake and electronics. I'm a old school chevy man and it looks like it would fit but not sure about the difference with a vortec. any help or directon in which way to go will be greatly appreciated.
Old 03-18-2008, 10:21 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
wrong post
Old 03-18-2008, 11:00 AM
Yes it would, taking his heads and intake, plus his timing cover, and damper.
His 97 is a Vortec and your early 90's is a swirl port. The difference is mostly the top end (Vortec heads and intake) needed to match his electronics and injection systems. Plus the plastic timing cover which holds a crank position sensor the Swirl port doesn't use and the Vortec damper which has the segments the crank position sensor is looking for.
Bogie
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
9" to chevy conversion bigiron Transmission - Rearend 4 10-11-2005 10:32 PM
73-87 chevy crossmember in 47-54 chevy ad swvalcon Suspension - Brakes - Steering 2 01-17-2005 07:34 AM
36-39 Chevy Sedan frames Rufus_2 General Rodding Tech 5 09-02-2004 12:52 PM
New Member Introduction - 48 Chevy Rodder 48 Chevy Rodder Hotrodders' Lounge 0 10-20-2001 03:04 AM
