chevy high pressure power steering hose - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2005, 05:00 PM
I have a 71 Chevelle and the high pressure power steering hose has a crack in the steel part of the line about 1/4 inch from the end. In trying to find a hose it looks like the ends are both male ends. My hose is male on the steering box but female on the pump. Can some one look at theirs and see if it has two male ends or a male and female. I am going to have a new hose made tomorrow. I would like to know if someone changed the fitting in the back of the pump or what?
Old 08-08-2005, 02:14 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
It's just a double inverted flared fitting. Buy an adapter.
Old 08-09-2005, 08:11 PM
Actually its a 7/16 inverted flare on one ond and a 3/8 flare on the other. I have a shop making a new hose. They dont have the inverted flare end so its going to be 3 days unutil they get it in. My only regret is the old one was chromed and they dont have the chrome ends. I guess I will have to braid it so it wont detract from the car.
Old 08-10-2005, 07:22 PM
Which end is the hard one to get? You can replace the pressure fitting on the back of the power steering pump with one from GM or a j/y with something more common. If I was going to have something custom made (with my luck) I would go ahead and have them make 2...one for the trunk.
Old 08-10-2005, 08:01 PM
The one on the pump is the odd ball one. I am not worried about it as its not a critical application. If this one goes bad I will pull the belt and drive it home with out the power steering. I did get the new hose today cost 40 bucks but it doesnt leak. The stainless braid I had is too small to fit over it so I will have to get some larger for it.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Small Block Chevy Oil Pressure knizet Engine 25 03-21-2008 04:21 PM
Power steering pump 1985 chevy k10 HELP! redneckrodder Suspension - Brakes - Steering 2 12-17-2004 05:11 PM
Jaguar and Chevy power steering systems Neophyte Suspension - Brakes - Steering 4 08-27-2004 08:55 AM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
