Chevy hot start - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2007, 09:12 AM
Chevy hot start
I have a 79' GMC 3/4 ton 4x4 with a 0.060 over 350 and headers that I'm having hot start issues with. I have relocated the starter solenoid to the firewall, but i still have the same problem.
I built the engine with too much compression for pump gas, but I've been driving it that way for several years and have pretty much thrashed a few pistons from detonation. When the engine was fresh, I didn't have the starter problem. I've changed the starter once and it didn't seem to help much. Any suggestions?
Old 11-19-2007, 09:17 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
You could try a heat shield between the starter and the headers or you could try some header wrap on the headers in that area or you could do both.
Old 11-19-2007, 09:18 AM
31 five window
Last journal entry: Moving along with patch panels.
Buy a high torque mini starter they work great.
Old 12-03-2007, 10:10 AM
Thanks for the advice fellas.
I installed new 2/0 battery cables and bought a 750 cold cranking amp battery.
It is working great so far, but the weather hasn't been hot lately. I'll see if my fix was successful next summer when it is 100 degrees.
I believe the cables were breaking down and that was the problem. That would help explain why I didn't have this problem when the engine was fresh and the cranking pressure was higher.
Old 12-03-2007, 10:26 AM
poncho62's Avatar
Wiki Edits: 5
Hot starting problems are usually due to too much advance in the ignition timing .......
Another cheap trick you can do is..........Install a shutoff switch for your coil. That way, you can get it cranking without ignition and then click it on........
It,s also a good anti theft device, if the switch is hidden.
Ontario Rodders
Old 12-03-2007, 10:29 AM
NEW INTERIORS's Avatar
Set no limit's on yourself
I bought a brand new mini starter off of ebay from a store,I think he sells them for $57.00,Worked great.Had problems with my big block starter getting hot Bought the mini starter no more problem
Old 12-08-2007, 02:51 PM
runn141's Avatar
SB S10
i always put a heat shielded sleeve over my cables, seems to help.
1997 Chevy Truck 1500 5.7 Wont Start Rebel Racing 3 Engine 10 01-16-2007 11:13 PM
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
hot start problem kszew Engine 2 09-30-2003 08:42 PM
350 hot start 74huggerorange Engine 9 03-04-2003 08:52 PM
Hot start problem-Not starter related Catalina Engine 4 11-13-2002 04:54 PM
