Chevy II Front Brake Conversion problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2007, 08:24 PM
Helped change buddies Chevy II front drum to disc brakes. Have bled system and cannot get any pedal, we checked master cylinder, measured plunger to see if correct, all okay. After checking master cylinder, still cannot get pedal, so we unhooked brake lines and plugged master cyl and got a good pedal. Then we plugged proportioner valve and had good pedal there. Hooked back brake line up and bled lines, finally got good pedal on back brakes. Then we unhooked back brakes and hooked up front...still cannot get good pedal on front. The way the front brake line is hooked to proportioning valve, should we run dedicated line from proportioning valve to each front wheel? Does anyone think this will help or are we doing something wrong all together? I have heard power bleeding might help but I don't understand how this will help if we are getting good fluid out of all lines (front and back) Some one please help....frustrated.
Trevor
Old 04-04-2007, 05:45 AM
48ChryslerRodder's Avatar
Stuck in the past.
The first thing to check is if you really have bled the calipers. Try taking the caliper off and the bleed it so you know that the bleeder is at the top and you get all the air out. any air will make it very soft pedaled. Keep working back to the master cylinder and you should find whats wrong. Good luck
Old 04-04-2007, 06:51 AM
T-bucket23's Avatar
Wiki Edits: 26
Did you put the calipers on the correct side, the bleeders must be at the top. I have seen this many times where the wrong caliper is installed on the wrong side. If the bleeder is at the bottom you need to swap them arround.
Old 04-04-2007, 08:34 AM
Chevy II Brake Front Brake Conversion Problem
T-bucket23-
Thanks a million, I know that is what we have done wrong. Have stared at those for so long, didn't see the obvious. Thanks again
Trevor
Old 04-05-2007, 07:00 AM
T-bucket23's Avatar
Wiki Edits: 26
No problem, I have seen it quite a few times. Please let us know if that was the problem.
Chet
Old 04-05-2007, 08:10 PM
Relieved and can sleep again
T-Bucket23
Took all of 5 minutes to bleed it, works great. Thanks again, you were a life saver.
Trevor
It's a Mustang II, but what's in it? And a brake problem . . . hduff Suspension - Brakes - Steering 4 11-19-2006 06:00 PM
Looking for Brake Hose for Mustang II front end john35 Suspension - Brakes - Steering 3 07-09-2006 11:10 PM
Brake System problem Bluepen Suspension - Brakes - Steering 3 02-16-2005 03:38 PM
Front disc brake conversion ideas oldsjetstar Suspension - Brakes - Steering 2 11-24-2003 08:53 AM
68 Chevy II disc brake swap krangar Suspension - Brakes - Steering 1 01-26-2003 06:11 AM
