Chevy II Front Clip Help
I have a 62 Chevy II that I am considering installing a new front clip from a donor vehicle and would like feedback on the idea I have in mind.
I also have a 1980 Chevy Luv and have a SBC in it already with headers already tucked inside the frame rails and it has discs already and thinking of cutting the front end off the Luv and doing a little fabrication work and installing it on the Chevy II. My ultimate goal is to have a tilt front end on the Chevy II and thus need to get rid of the shock towers on it and have something a little better handling than the old Chevy II front end. Any thoughts on the swap? I do have some older ET type mags on the Luv and the front wheels are the stock 6 bolt hub so think I might be a little limited in wheel selection. Could always go with the old wheels for more of an old school look. How do you think the steering will work? I saw in another thread about using a Camaro clip in a Chevy II with some concerns about the steering box. Any help is appreciated. |
sweet
yea if you go with the camaro clip still a ton of work i would buils a square tube clip and do a tube upper controle arm and do a heim style lower with coilovers no you dont have to spend 7,000 on a clip then another 2.000 to put it on you can build a clip on the ground as long as you build fixtures to keep it square and do all you tabs for controle arms and rac steering etc when its on the car if you need some ideas email me directly boosting27psi@yahoo.com i have done tons of clips and conversions did some rhd clip swaps and stuff and built clips for race cars forever so jujst shoot me an email
On your price.. And as far as building a new one,I can put a clip on a car before you even build your jig..
ok
yea i clip racecars for a living right way wrong way jigs thats why there made because when you weld thet twist there bud
I'm very aware of how to do it.. I have been down that road more then once.. ![]() This is a frame I just built for my 41 willys..
and ill admit prices are a little off but thats with like the best of best parts
hey that looks like a buy jk nice work how do you post pix
I have a Art Morrison front end on my 41 frame and It was only About $3300.00 and you can't buy much better then that..$7,000 for a clip.. Man the a-arm's must be made out of ''Gold''...
tube upper sweet mfg rac speed way spendals and willwood 6 pistion calipers and willwood hubs slotted and drilled wilwood rotors and ohlins coilovers o yea and then buing the chassis from f body creations
Control Arms
Have you seen the Church Boys Control Arms and their steering set up? It is made for a Chevy II. Only problem is they don't have the upper arms yet to get rid of the shock towers and I want to tilt the front end and need to get rid of the shock set up the Chevy II's had.
Here is their link. http://www.churchboysracing.com/ What do you think? I have read some on them and the reports I have seen say they are pretty good, but the top arms would have to be figured out. Any ideas on that? |
i spent 5800 on the frontend then a shop wanted 120and hr to put it on because i didnt have the time o yea for a 79 camaro
Well when the guy asked about a Camaro Clip,I don't think he was wanting all the best money can buy..Usually people that want to clip there car is looking for a easy and cheap way to go...And most of the time putting A Camaro clip, Is the way to do it the cheapest and get a very good ride..And A lot of the Camaro clip's are in good enough shape to put them right in without costing any where's near $7,000 plus $2,000 ...Man What did you say the name of your shop was ???
there not bad but yea uppers still an issue u just need to go with tube chassi set up with and upper controle arm and coilovers the best fix
Sorry.. but they took you for your money..
| the history of chevy v8's | savman1 | Hotrodders' Lounge | 43 | 03-02-2012 06:57 PM |
| Chevy II Front Brake Conversion problem | Trevor Horn | Suspension - Brakes - Steering | 5 | 04-05-2007 08:10 PM |
| front clip suitable for 55 chevy | duane mantle | Introduce Yourself | 7 | 12-07-2004 09:33 AM |
| front clip replacement on 1953 Chevy Truck | chevyheaven1 | Suspension - Brakes - Steering | 3 | 11-08-2004 09:17 AM |
