Chevy Inline 6 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2008, 06:03 PM
solidaxel's Avatar
Last journal entry: Project garage complete!
Chevy Inline 6
Engine was missing checked electrical found O K
checked carb found O K
checked compression found 5 O K !!!
Removed valve cover and found one push rod bent. reason for miss O K
Now for the question straightened out the push rod and dropped it back in the head and it went all the way into the head flush with the boss, have not removed the inspection cover yet. what am I going to find???
the 2 cylinders beyond the bent push rod were still working, good compression. I am thinking a flat cam or a busted lifter, is that possible I mean the busted lifter?
Would someone please take a photo of a Chevy 6 cylinder with the inspection cover removed so I can see the lifter galley, as I will not be able to get back to it for a few days.
Thanks for your help
Old 10-12-2008, 08:27 PM
which inline 6 are you asking about?
Old 10-12-2008, 09:36 PM
solidaxel's Avatar
1948 216 ci
Old 10-12-2008, 10:21 PM
When pushrod bent, lifter could have jumped out of lifter bore! Very common on engines that were running at RPM when pushrod bent....also lifter could be broken as well!
Old 10-13-2008, 09:03 PM
solidaxel's Avatar
Thanks,
I am hoping for the push rod jumped out of the lifter.
What is the chances of straightning the push rod and reusing it, until I can find some new ones, are they all the same length?
Old 10-13-2008, 09:06 PM
you can buy new pushrods from Jim Carters for $5.23 each
http://www.oldchevytrucks.biz/47_55/full.asp?page=99
Old 11-23-2008, 09:43 AM
solidaxel's Avatar
All is good just need to adj. valves.
Thanks for all of your encouragement.
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 06:43 PM
What's the best carb & fuel tank replacement for a 1955 Chevy 235 straight six? islandman Engine 5 09-17-2011 10:50 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
chevy inline 6 sdbrooks@cebridge.ne Introduce Yourself 2 01-01-2007 02:14 PM
