-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   Chevy k-5 Blazer seats in Truck (http://www.hotrodders.com/forum/chevy-k-5-blazer-seats-truck-228862.html)
red82c10 01-26-2013 10:13 PM
Does anyone know if the bucket seats out of a K-5 Blazer will fit into the C series trucks without much modification? I'm hoping the outer mounting holes might be the same and only the interior facing holes in the bucket seats would need to be drilled in the floor. The truck has the factory bench seat.
The Blazer is 1986 model and the truck a 1982.
Thanks,
Matt
timothale 01-26-2013 10:35 PM
floor braces
There might be floor bracing for the buckets, check the blazer, and if you are junking it, cut them out, weld them in your truck or use 3/16 pop rivets.
kso 01-28-2013 11:26 AM
The floors are pretty different...the p/u is contoured to work around the side-saddle fuel tanks and the Blazer is more flat, having the tank in the rear.
That said, they are the right size...and the mounts can be cut down and welded to plates which in-turn can screw to the floor.
