chevy main bearings WHAT ARE THESE - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2011, 08:59 PM
ok i have so main bearings and i need some help figuring these out on the tab side starting at the top a circled A and right net to the A it says 55084 also GMM400 bearings are in great shape but im putting in some flat tops so im going to change the bearings as well forgot to say chevy 350
ID:	51479   Click image for larger version
Old 01-08-2011, 09:06 PM
DoubleVision's Avatar
GM Moraine 400 bearings. Which are excellant. I don`t think GM makes these anymore.
Old 01-08-2011, 09:13 PM
ok sweet that puts me one step closer but how do i tell if the are std .010 etc etc?
Old 01-08-2011, 09:16 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Those are the OE "Moraine 400" bearings GM had used forever, it seems. Clevite bearings would be a good replacement.
If there's no sizes stamped, they're most likely standard.
Be aware that the factory used select fit bearings to tailor the oil clearance to the crankshaft, so you may see a standard bearing, a bearing that's 0.0005, etc. used to get the proper clearances. These bearings can be found on any journal- in fact I'd be surprised if the crank had ALL standard bearings throughout.
The size stamping can be on the opposite end and can be very light. Clean them off real good and use some light and magnification if needed to read the sizes. Keep them in order so you will know what bearings went to what journal in case there's any damage to them.
In the case of your crank, I'd mic it to see what the journals looked like for size and taper and choose the new bearings accordingly. Even if it mic's OK for standard bearings, you might consider giving the crank a polishing, even cranks that look good to the naked eye can need polishing, IMO.
You can also use a standard bearing half w/a 0.0005 bearing to tighten up the clearances, for example.
Old 01-08-2011, 09:20 PM
all of them are like this one this one say the same thing
Old 01-09-2011, 06:59 PM
cool thanks im going to mic it just gotta get them back from work also the piston bore but the pistons dont say anything on them and appear to be factory dish
283 Main bearings Mertz Engine 4 09-15-2010 10:21 AM
Are these the correct bearings?? (main bearings) LandonL Engine 3 08-29-2010 08:46 AM
Rod and main bearings sledneck307 Engine 17 03-23-2009 12:36 PM
main and rod bearings neverfastenuff Engine 2 03-01-2009 02:47 PM
Main Bearings k-star Engine 5 07-22-2004 05:41 PM
