chevy master cylinder on dodge. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2009, 06:32 PM
Rubberman2003's Avatar
I have a 93 dodge dakota that im doing a frame of resto on. Its v8 5 speed, 4x4. Silly to do all that for that truck, but i was bored! There is a newer Chevy Tahoe at my work, with a fairly large brake booster and master cylinder. Would it be possible to swap these into my dakota. The cab is off the truck, so it would be very easy if it will work. Just curious, thanks
Old 01-26-2009, 06:40 PM
302 Z28's Avatar
Sure it can be made to work, if you have access to every thing that is needed and have the expertise. There are very few things that absolutely cannot be done.
Vince
Old 01-26-2009, 06:46 PM
Ok cool. I havnt looked at it close enough, if it has lines running to a ABS unit, can i just run those lines right to my calipers? I dont have abs on my truck.
Old 01-26-2009, 06:58 PM
302 Z28's Avatar
Depending on how new that Tahoe is, that ABS system could be very complicated and I would try to transplant all of it to the Dodge. I could not possibly make an assumption you could not use the existing ABS control system of the Tahoe.
Vince
using only the master cylinder and takin out the break booster Arillious Suspension - Brakes - Steering 12 08-14-2007 11:02 AM
50 Chevy truck master cylinder kit mr52pickup Suspension - Brakes - Steering 1 11-22-2006 12:01 AM
54 dodge master cylinder modification Magnus_Jager Suspension - Brakes - Steering 2 01-04-2006 08:38 AM
Confusing master cylinder ports... Externet Suspension - Brakes - Steering 2 12-08-2003 08:18 PM
chevy 305 cylinder relined DADDYBLUE Engine 4 02-13-2003 05:56 PM
