-   -   chevy monza trans swap (http://www.hotrodders.com/forum/chevy-monza-trans-swap-124001.html)
dcoates18481 09-09-2007 12:42 PM
i am looking to put a glide or th-350 in a monza i'm building with the stock rear( for now )..
my question is, can i take the tailshaft cover from the original trans ( i think a th 200 ) and put it on the glide or th-350.
the reason i want to do this is the original housing has the provision for the torque arm.
unless someone knows a way i can mount the torque arm differently? :thumbup:
thanks
Crosley 09-09-2007 10:01 PM
thanks
A t-200 does not have a removable tail housing.
the OEM trans in the Monza may be a t-350 trans. That tail housing will NOT fit a glide.
photo of a Monza t-350 trans. GM left off one bolt hole location because of the lack of space at the firewall.
http://hotrodders.com/gallery/data/500/dcp_0706.jpg
dcoates18481 09-09-2007 10:42 PM
i think you're right.
thanks for the tip, 350 it is.
i'll put the glide in the 75 with leaf spring narrowed setup.
thanks again.
Dave
