chevy monza trans swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2007, 11:42 AM
i am looking to put a glide or th-350 in a monza i'm building with the stock rear( for now )..
my question is, can i take the tailshaft cover from the original trans ( i think a th 200 ) and put it on the glide or th-350.
the reason i want to do this is the original housing has the provision for the torque arm.
unless someone knows a way i can mount the torque arm differently?
thanks
Old 09-09-2007, 09:01 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
thanks
A t-200 does not have a removable tail housing.
the OEM trans in the Monza may be a t-350 trans. That tail housing will NOT fit a glide.
photo of a Monza t-350 trans. GM left off one bolt hole location because of the lack of space at the firewall.
Old 09-09-2007, 09:42 PM
i think you're right.
thanks for the tip, 350 it is.
i'll put the glide in the 75 with leaf spring narrowed setup.
thanks again.
Dave
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
1953 chevy frame swap Bwagner General Rodding Tech 3 07-01-2004 08:35 AM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 11:14 AM
trans swap rizzo59 Transmission - Rearend 1 12-19-2003 04:21 PM
Stude to Chevy engine swap Dawger General Rodding Tech 3 07-11-2003 07:15 PM
